t88 turbine wheel lightening
I've found a company that will lighten the wheels in my t88 by 10% and 15%. Does anyone know how this will, if at all, improve the response of the turbo ?? Would it require a remap too ??....Thanks...Kev.
It's a company called ForcedInductions.com in the US. This is what I was told:
"We can do modifications to the wheels and bearings to make the turbo spool a little sooner, but its marginal. We can lighten the wheel by 10% and turbine wheel by 15% as well." The price seems good at around $600. It includes labour and parts. I don't want to go thru the cost of a remap and new turbo. My goal is to have the turbo start spooling 500rpm sooner.... |
Its not clipping the wheel is it ?
Clipping works...but its kind of a ghetto way to do it. Mike Kojimas article on clipping exhaust wheels . http://www.nissanperformancemag.com/april06/nerds/ |
#7 (permalink) | |
This all assumes theat the Garrett engineers that designed the compressor wheel in the first place seriously screwed up the original design.
It suggests they placed additional material into the wheel that adds significant weight without adding any strength. It may not matter if you are only running low boost, at low compressor Rpm. But if you are seriously pushing that compressor to a high pressure ratio, I would be a little bit careful. Most of the rotating inertia is in the turbine anyway. |
I would say the Garrett guys didnt have much to say about the Mitsubishi turbo the T88.
Turbine and compressor design is advancing. An old turbo works, but a newer one is more efficient. Its like a carb, they work, but fuel injection works better. |
#12 (permalink) | |
