Old 19th January 2007, 09:15 PM   #250 (permalink)
ISL33P
ISL33P's Avatar
Send a message via MSN to ISL33P
uses the signal from the standard CAS.
yes they use race fuel, but why risk all those hard earned dollars (pounds) on the crap you buy at the pump. if you are going to run any serious boost figures, its the only way to go. if you drive it on the street, just select a conservative tune with little boost.
ISL33P is offline   Reply With Quote
