Originally Posted by ISL33P
uses the signal from the standard CAS.
yes they use race fuel, but why risk all those hard earned dollars (pounds) on the crap you buy at the pump. if you are going to run any serious boost figures, its the only way to go. if you drive it on the street, just select a conservative tune with little boost.
I see.... Motec is a very good ecu, no doubt!
If i had the money i would go for one. I am currently using electromotive, wich i find has probably the best / most accurat ignition system.
Motec can probably adjust ignition scatter? and ignition on each sylinder aswell?
