Originally Posted by ExScoobyT
Typical internet BS relating to the nissan CAS! The problem is the AEM ecu not the bloody CAS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
How would you explain everybody`s problem when using ecu like aem, powerfc, link etc etc ?
I have seen this many times now, and hear about it all the time.
When you use it for a 400hp engine there is no problem, it is when you come up to 5-600 ++ hp, and using pump fuel.
Not every one can afford a system like motec, or run a daily driver on racefuel. Or have a HKS ecu, there is not one powerwriter in norway, so that means i have to go to uk everytime i want to change something on the map or settings etc....
Asim...
