Old 19th January 2007, 11:22 PM   #257 (permalink)
Asim R32GTR
Asim R32GTR's Avatar
Originally Posted by ExScoobyT View Post
I am not suggesting that there are not harmonics present in the rotational signal from the CAS, however that is easily dealt with in the software, which no one on here is able to inspect. The fact that the CAS has 360deg markings and 6 windows suggest to me that the RPM signal is processed in varying ways according to the RPM (Correlation of cylinder windows with crank angle degree, coupled with rotational acceleration rationality checks - note the varying window lengths). The whole nissan CAS issue was only raised after multiple users (me included) had issues with the piece-of-crap AEM ecu that is clearly unable to process the signal correctly.
Do you really think Nissan would use a fundamental sensor that did not work (Grp A racers included?). The car was manufactured for what 9 -10years? I must have missed the change to crank AS on R34 or Z-tune, or mines or HKS or or or or......
For info the 360deg markings would give rise to a 24Mhz signal at 8000rpm, a 60-2 gives a 8Mhz at 8000rpm.
The problem is with non_nissan ecu`s.... Apperantly nissan has a fix for this in the stock ecu... and the stock ecu isnt exactly a tuners dream...
