Old 16th November 2002, 12:18 PM   #1 (permalink)
RoboPope's Avatar
R33 GTS25t Maximum boost?
Folks,
Anyone know what the maximum boost pressure the standard R33 GTS25t engine will tolerate providing the head gasket has been replaced with a steel one?
Most of the peripherals are in the process of being changed so hopefully they will not be impeading my quest
Paul
RoboPope is offline   Reply With Quote
Old 16th November 2002, 05:03 PM   #2 (permalink)
Calv GTSt's Avatar
Hi Paul
Im running 1 bar on mine though mine is running standard compression. Im told you can really start to blow em when youve lowered the compression. But how high will depend on the rest of the mods.
Calv
Calv GTSt is offline   Reply With Quote
Old 16th November 2002, 07:07 PM   #3 (permalink)
RoboPope's Avatar
Calv,
I'd imagine that’s is a similar boost level that mine will come back in, I’ll post the rolling road figures when I get them so we can look at the differences from the last tweak
So how do you go about lowering the compression? I dare say you cannot affect it too much with a thicker head gasket.
Paul
Old 16th November 2002, 08:17 PM   #4 (permalink)
Calv GTSt's Avatar
Paul
To lower the compession on these you can fit a thicker head gasget, I dont know whether the head gasgets come in a range of thicknesses, does the one you have ordered maintain standard compression?
I know that by lowering the compression you will loose some off boost performance.
Calv
Old 16th November 2002, 08:49 PM   #5 (permalink)
RoboPope's Avatar
Hmmmm.... guess i'll find out although I have absolute faith in them to get it right though. This round of mods started out as a bit of a service and sort the clutch which has been a bit lame since ive had the car. The trouble is that as usual i started to behave like a kid in a sweet shop and so im not sure what to expect yet.
Paul
Old 17th November 2002, 07:48 PM   #6 (permalink)
uk_skyman's Avatar
Send a message via MSN to uk_skyman
Paul im running 0.8 bar but ive been told thats max on the 'plastic turbo' looking for steels like Calv so i can go 1 bar too....
Dean
ps: dont switch the apexi boost kit off as i reached over 1.4 bar in a split second untill i s**t my self and switched it back on
uk_skyman is offline   Reply With Quote
Old 18th November 2002, 01:27 AM   #7 (permalink)
RoboPope's Avatar
Dean,
I already have a needle rollered trick turbo so hopefully i can run higher than that but i dont know what the engine its self can do... sadly without cams all that boost is not likely to be used that efficiently. still that just means another trip to the toy shop
Paul
Old 17th December 2002, 03:38 PM   #8 (permalink)
R34Nismo's Avatar
Did I see you in Finch Mr Pope ?
___________________
HQ is Now Closed
Note for Marketing Agencies - McDONALD'S Make your brown carrier bags green in colour so they blend in with the countryside after they've been thrown out of car windows.
R34Nismo is offline   Reply With Quote
Old 17th December 2002, 03:42 PM   #9 (permalink)
RoboPope's Avatar
It is distinctly possible I spend a lot of time up the California end of Nine Mile Ride
Paul
Old 17th December 2002, 03:44 PM   #10 (permalink)
R34Nismo's Avatar
S'pose thats why i live off of Barkham Ride
___________________
HQ is Now Closed
Old 17th December 2002, 03:50 PM   #11 (permalink)
RoboPope's Avatar
yep, that'll do it
Old 23rd December 2002, 05:09 PM   #12 (permalink)
I think you need also a fuel cut defencer, this helps you raise the boost without detonation. Links up to the standard ecu.
hks do one for about £100.
hope that helps.
swishboy
swishboy is offline   Reply With Quote
Old 23rd December 2002, 05:16 PM   #13 (permalink)
uk_skyman,
I have the profec b boost controller setup on my r33gts-t and it will only get in to too much boost if i turn the boost controller on, and too high.
Most of the time i have it turned off as the standard boost is limited to 0.7 bar, on stock ecu. I'm gonna get the hks fuel cut defencer fitted and i'm told with my hks head gasket, that i will be able to make 1.0 bar on standard turbo.
Also i have found that to get really impressive boost i select the high end boost as low end just lose's traction
P.s happy xmas skyliners
swishboy
Old 23rd December 2002, 06:19 PM   #14 (permalink)
uk_skyman's Avatar
Thumbs up i know the feeling
in this weather 1 gear forget hard accelleration 2nd as 1 but in third its ok untill about 6000 revs till the back goes a bit leiry but heh does it suck at 1 bar or what, the blitz induction sounds great and the blitz blow of sounds much loader now at 1 bar...
merry xmas Dean
Old 23rd December 2002, 07:12 PM   #15 (permalink)
RoboPope's Avatar
I dont have a standard ECU, injectors or AFM... plenty of scope to play there I think
bring it on santa
a very festive Paul
