Old 18th November 2002, 12:27 AM   #1 (permalink)
Peter's Avatar
Found this in my
catchtank! First time of emptying, after a few months and 2 or 3 track days. The yellow liquid at the bottom isn't flammable so I'm guessing it's water based....?
Anybody else done their's, does this look a similar type of gunk?
Old 18th November 2002, 08:45 AM   #2 (permalink)
DCD
DCD's Avatar
Send a message via MSN to DCD
Damn thats a lot of gunk!! Looks like a pint with lots of head!
Old 18th November 2002, 08:57 AM   #3 (permalink)
Peter's Avatar
Not sure it would go well with a packet of crisps though Dino.
The grey 'head' is an oily emulsion so I presume that water vapour is present in the crankcase presumably as a result of combustion and blow by....?
There's about 1/2 litre in total so not too much. I've heard of several guys on here having to empty their catchtanks after a single day on track....
Old 18th November 2002, 09:33 AM   #4 (permalink)
dan0h's Avatar
I'd be very surprised to find any water vapour in the crankcase ventilator system ... Oil and water should never really meet in any engine.
Unless I'm a total gibbering muppet I'd say something doesnt look quite right there, check out that head gasket ... hopefully its nothing sinister (ie. Cracked head/Block).
I hope for your sake I'm completely wrong ... but I'd be quite concerned if I'd just got that out of a catchtank.
Cheers,
Dan
dan0h is offline   Reply With Quote
Old 18th November 2002, 09:49 AM   #5 (permalink)
Peter's Avatar
She never uses a drop of water Dan so no worries there. As I understand it, and I'm sure somebody will confirm this or correct me (Mycroft, Mark, Gary..?), when running higher boost, you get piston blow by whereby some of the combustion gases get into the crankcase. By their nature, these gases will contain water vapour so I presume that when these enter the catchtank, they condense and get caught there. This would also explain how people get petrol in their catchtanks which I've heard has happened to at least two of the guys on here.
I'm interested to know what others have found in their tanks.
Old 18th November 2002, 11:22 AM   #6 (permalink)
Banned
Mycroft's Avatar
Send a message via ICQ to Mycroft Send a message via AIM to Mycroft Send a message via Yahoo to Mycroft
As I don't 'know' your car and Gary or Mark do (they may even have serviced it) I do tend to see this sort of thing as being Gary and Marks 'province, but as far as I'm concerned this looks OK, if the timescale and use is as you say, but I would 'monitor' the tank very closely for the next few months to be 'safe'.
What I will add is that there is some evidence there of driving a little too quickly before the car has fully warmed or driving the car on lots of short journeys (one or t'other). I say this because I remember reading somewhere that more than 10% water content in a catch tank is indicative of this, but I have no direct experience of Skyline engine tuning.
Old 18th November 2002, 11:46 AM   #7 (permalink)
Peter's Avatar
Definitely not the former but the latter is correct of late.
Thanks.
Has nobody else ever emptied their catchtank?
Old 18th November 2002, 11:59 AM   #8 (permalink)
SteveC's Avatar
Dirk was telling me about when he emptied his before Brands.
Said there was a layer of water, then oily type residues of various colours. kind of like a tequilla sunrise for a petrol head !!
I fitted the breather to mine the other day so there are no smells at all now.
It vents out the back so people behind can have the pleasure.
/Steve
tdi
SteveC is offline   Reply With Quote
Old 18th November 2002, 12:24 PM   #9 (permalink)
RonS's Avatar
Post
Yeah... seen a mate drinking this, it's combination of guinness and lager, try it Peter if it tastes like engine oil and water, that'll be it
RonS
RonS is offline   Reply With Quote
Old 18th November 2002, 02:14 PM   #10 (permalink)
dan0h's Avatar
Originally posted by PeterE
...when running higher boost, you get piston blow by whereby some of the combustion gases get into the crankcase. By their nature, these gases will contain water vapour so I presume that when these enter the catchtank, they condense and get caught there...
Fair enough, I'm just surprised that its that volume of water, seems like it would take an amazing amount of vapour to create that sort of level of water. I would have thought the heat inside would bake any moisture out long before it gets into the catchtank ... Mycroft as always has the wisest words
Again, just seems a lot of water
I stand corrected Let us know any developments though...
Cheers,
Dan
Old 18th November 2002, 02:19 PM   #11 (permalink)
Peter's Avatar
Where to? The vapour can't escape the engine, no where to go until the vapour exits the breather system, i.e. into the catchtank. Without a catchtank, it all gets sucked into the intake.
Ron,
Where you been hiding? I'll have a sip later, maybe bottle it for real petrol heads....
Peter.
Old 18th November 2002, 02:23 PM   #12 (permalink)
lightspeed's Avatar
Also when the weather is cold and the car left standing (typically overnight) condensation forms on the inside of the engine.
This will end up in the catch tank as well as any water vapour from blow-by.
This time of year it will really make a difference.
Old 18th November 2002, 02:27 PM   #13 (permalink)
Peter's Avatar
Yes, good point, hadn't considered that...
Old 18th November 2002, 02:38 PM   #14 (permalink)
dan0h's Avatar
I'll get my coat Good point again... Ditto lightspeed...
Old 19th November 2002, 07:58 AM   #15 (permalink)
SPOOLIN's Avatar
Mine looked similar to that when i emptied it (had to replace parker globe which is behind catch can). Although mine was a little creamier and i didn't let it sit so i could separate. It did smell strongly of fuel.
Does your engine only vent to the catch can through the 2 breathers on the top or do you have bundy (ally tube) coming from the sump aswell?
Hope this helps
Lee
SPOOLIN is offline   Reply With Quote
