Old 20th November 2002, 08:34 AM   #1 (permalink)
slippyr4's Avatar
Stand Turbos vs HKS 2530s
Morning all,
I know standard turbos (with ceramic giblets) are "safe" to 1.0 bar...
What kind of boost can you realistically run with them sorted with steel bits inside? I'm presuming you're limited by the size/flow of the turbo rather than a might shatter type break scenario. So, what might I be able to run steel standards on? How does that compare to HKS 2530s ? What is their max boost?
Thanks
Jon
slippyr4 is offline   Reply With Quote
Old 20th November 2002, 09:08 AM   #2 (permalink)
hipogtr's Avatar
Bolting on direct replacement steel blades onto the factory turbos won't get you a lot more room for boost. The factory turbos were "designed" to operate at about 1 kg/cm2 so pushing them beyond 1.2 kg/cm2 begins attracting decreasing returns to scale, both on the compressor (heat) and turbine (backpressure) sides.
On the other hand, the HKS 2530s were designed to operate in higher boost conditions and actually start their sweet spot from 1.2 kg/cm2. ith those turbos you could go up to 1.7kg/cm2 before starting to encounter the same decreasing returns to scale as mentioned earlier.
Note, these are simply indicative numbers - your mileage may vary.
Cya O!
hipogtr is offline   Reply With Quote
Old 20th November 2002, 06:45 PM   #3 (permalink)
Henry's Avatar
BHP difference
At Tuning Japanese,Guy`s R33 LM (now Durzels) made about 480bhp with steel internals,his R34 with 2530`s got to 570-580BHP both figures at the flywheel.
Keep the boost down,trust me.
Maybe Guy could follow this post up with more info.?
Henry.
Henry is offline   Reply With Quote
Old 20th November 2002, 07:28 PM   #4 (permalink)
Guy
steels vs 2530s
Both were a while ago, so I can't remember the exact figures, though I recall the 2530s made 545bhp (I think), can't remember the steels.
Generally I'd say a set of steel internal stock turbos are not efficient above about 1.2bar and are limited to about the 460bhp level. A set of 2530s are efficient to about 1.5bar and good for about 570bhp.
The above will depend on other engine mods and tuning (cams/intercooler are necessary for power above).
There is little point running steel internals as if you want more power it is a better step to jump to bigger aftermarket turbos (for not much more overall cost).
There is no point running high boost unless you have big big turbos as the compressors are beyond efficiency and all you do is make heat, not power. and lower the longevity of your engine.
Guy
Guy is offline   Reply With Quote
Old 21st November 2002, 07:30 PM   #5 (permalink)
What about lag??
At what point in the PRM range would you expect to hit full boost on these turbo's - Ceramic vs. Steel vs. 2530's
This will make a huge difference to the drivability of the car.
alex h is offline   Reply With Quote
Old 21st November 2002, 10:20 PM   #6 (permalink)
Send a message via AIM to TALAL Send a message via Yahoo to TALAL
Re: steels vs 2530s
off topic ....hi guys this is my first post here and my english isn't that good so i need help from you guys .. i'm planing to buy those bolt ons turbos such as HKS 2530 but the thing is i dunn know where to buy them from or how much do they cost in $ dollars shipped to the middle east ...... thanks in advance
TALAL is offline   Reply With Quote
Old 21st November 2002, 10:31 PM   #7 (permalink)
slippyr4's Avatar
Talal,
http://www.takakaira.com is a good bet.
Old 21st November 2002, 10:44 PM   #8 (permalink)
Originally posted by slippyr4
Talal,
cheers mate
Old 22nd November 2002, 05:46 PM   #9 (permalink)
Henry's Avatar
Alex h
Lag is not a factor.........change down a gear.
Henry.
Old 22nd November 2002, 07:01 PM   #10 (permalink)
Re: Alex h
Henry.
Too lazy
Old 22nd November 2002, 07:57 PM   #11 (permalink)
Henry's Avatar
Talking
Alex h,
Good answer!
Henry.
Old 22nd November 2002, 08:34 PM   #12 (permalink)
Re: steels vs 2530s
[quote]Originally posted by Guy
[b]Both were a while ago, so I can't remember the exact figures, though I recall the 2530s made 545bhp (I think), can't remember the steels.
what do you expact to run in the 1/4 mile if you are running 1.5bar or 550Hp GT-R ?
i read somewhere a gtr with 2530 + nos run high 10's @ 137 ...but that run was @ 1.7bar + nos ...
Old 23rd November 2002, 02:49 AM   #13 (permalink)
hipogtr's Avatar
NOS makes a huge performance difference, especially if it was a sizeable shot. The car that ran 10.7 is Motorex's R33. That car was being pushed very hard to get that time. On straight 2530s with a well tuned engine and driver you should be able to hit low to flat 11s (non-stripped GT-R) readily.
Cya O!
Old 23rd November 2002, 10:40 AM   #14 (permalink)
kingsley's Avatar
So when DO the 2530s build boost compared to the std turbos, and how does the spool up time compare?
Sometimes it's nice not to have to change down ... (I'm lazy too).
And is the 2530 the 'next size up' from the stock turbos?
Old 23rd November 2002, 11:46 AM   #15 (permalink)
Henry's Avatar
Next Step up.
HKS GT 2510`s are the next step up,they are excellent turbos and depending on cams will pull hard from 3,000rpm.These are brilliant trackday turbo`s and I should know as I covered over 30,000miles on mine before I moved on to the GReddy T517Z`s.
Peter E. and Jamie M. are well known 2510 users and Shin and Dirk Diggler (Andy Barnes) are of course two of the many 2530 guys on this Forum.
The GT25 range will give you anything from 480BHP to 620BHP at the flywheel depending on how modified your RB26 is.The 600BHP figures are achieved from the GT2540 and "R" versions.
Aren`t Saturdays boring without a Skyline to play in.
Henry.
