do you know what type of bulb your main beam is?
biggest problem i can forsee is HID takes a few seconds to warm up.
so, when you flick on full beam, it'll be dark/dim for a few seconds.
and again when you flick back.
on the halogen type you cannot have dipped and main on at the same time, even if you pulll back on the flasher, so its best to keep the full beam as halogen IMHO. maybe whack some monster bright lamps in there, as you'll use it infrequently
mook
