#1 (permalink) | |||||
RB30 Oil Pickup - discussion
Hi all,
Id like to carry on with what a few were talking about in one of the for sale threads (sorry for dragging that off topic, but it needed to be stated that the pick-up was modified for the new buyer) in regards to how people run the new oil pickup in their RB30/26 engines (non OS Giken of course). Quote:
The way im doing it on mine is running an external pickup. Remove welsche plug in the oil pump, fit -12 fitting, run braided line down to another -12 fitting in the side of the sump where the relocated pickup is. It's a bit of a pain on a standard sump as there aren't many flat surfaces to get a nice easy sealing surface, but is definately do-able. I can even grab some pics and add them so its easier to understand different ideas. Just after anyone's input that has an idea, or even half of an idea ![]() |
I know how mine works, how the oil is picked up and transferred to the oilpump, and a very cool way it is too, but im not telling, as i said i wouldnt, so, well, sorry!
What I will say though is although ive never seen a setup the same before, itd dead simple and obvious really, and way more effective than the standard setup. |
Good on you Steve, keep my tricks to yourself
There are many ways to get the oil from the sump to the oil pump, we usually use the blocks oil gallery, in Steve's case, he did not want to have A/C and he wanted something different so I designed a completely new external system which is now an option for any of my engines. At the end of the day, all you have to do is keep oil at the entry to your pickup tube at all times. Our 4wd adapters enable us to have internal or external pickups and the way we do it, I can't really see any advantages one way or the other, they have both proven themselves to be reliable and maintain good oil pressure. I can't see what all the fuss is about, either way is simple enough to do ![]()
R34 GTR: Quickest full street trim skyline in NZ, 9.7 @ 137 on 1st test pass, first meeting in the UK, 10.4 @ 144. RIPS 240z, WRH8.36 / 163 @ 1.9 bar, stock crank, stock block, petrol RIPS 240z, RIPS RB30, quickest/fastest Jap street car in NZ 8.36/163mph 1.9 bar. NZs quickest Pro Import on petrol. RB engine building, alloy and stainless fabrication, affordable skyline tuning and high capacity repowers, worldwide shipping arranged. e-mail rips@inspire.net.nz www.ripsracing.com
Cheers guys. I just wanted some documented discussion because i dont think there is anything describing this anywhere!
I can certainly understand that u want to keep ur own designs secret, because u had to do all ur own R&D |
#7 (permalink) | |
#8 (permalink) | |
Can you post some pics of your external p/u please?? j. |
