Old 25th November 2002, 11:08 PM   #1 (permalink)
increasing boost
Does any body know how too turn the boost up on a gts-t.
marv is offline   Reply With Quote
Old 26th November 2002, 11:33 PM   #2 (permalink)
some 1 must know how too turn the boost up without using a bleed valve, Its easy on other cars but a skyline isnt just any other car so want to make sure i got all the info i need....
Old 27th November 2002, 05:46 AM   #3 (permalink)
turbob12's Avatar
Boost
I've got an aftermarket boost controller on mine, I just set that to whatever I want. Don't know about standard cars though.
turbob12 is offline   Reply With Quote
Old 27th November 2002, 04:52 PM   #4 (permalink)
slippyr4's Avatar
There are 5 normal ways to increase the boost on most turbocharged cars:-
1. Weld the wastegate shut (not recommended)
2. Adjust ECU programming (not always possible)
3. Fit an electronic boost control computer (recommended)
4. Fit a mechanical boost controller (like a dawes device) (not heard of one on a skyline, hence not recommended).
5. fiddle with a restrictor....
... many turbo cars have a restrictor in the pipe that runs to the boost control solenoid. Eg. 200SXes. Removing this or making hole larger can increase boost. Tends to make the boost a bit out of control (spikes etc). It can make your car hit full boost at part throttle. Hence bad idea.
slippyr4 is offline   Reply With Quote
Old 27th November 2002, 05:23 PM   #5 (permalink)
gtsm's Avatar
Electronic boost controller only way to go
evc 5 is good i have on my car and is superb
lee
gtsm is offline   Reply With Quote
