Adam Kindness
has no status.
where to buy sump baffle
Looking for a sump baffle.
Pretty sure all the kits are much the same, but correct me if i'm wrong. Where can i buy them!?! Found a JUN and Tomei on Nengun. Did a quick search and couldnt find anything :/ JUN Baffle Plate - JUN - Oil Pan Baffle Plate - Nengun Performance Tomei baffle plate - Tomei - Oil Baffle Plate - Nengun Performance Are those prices good/bad? |
Adam Kindness
has no status.
also..... what mods are needed to be done to the sump to locate/fix the new baffle in place?
Engine complety out job, or can it be managed with just a slight lift? |
Abbey M/S
is is looking forwards to seeing 6,s at the pod this
year
Cars owned: Skylines...
Motor out, sump off to fit
Servicing/tuning all Skyline models since 1990 Up to date diagnostics for all Nissan,s Laser 4 wheel alignment equipment Corner weight scales for trackset up Tuner of the fastest Rb26 powered car in Europe Any information needed give us a ring or mail us We can work and tune cars that go round corners as well as work and tune cars that are fast in a straight line. http://www.abbeymotorsport.co.uk
Adam Kindness
has no status.
yup.... thought so :/ may as well get some other shite done while its out then LOL
Fixing the baffle in place.... whats the score with that? |
Marky_GTSt
is a Fire Engine
Cars owned: Skyline GTSt
Bit of a hijack but does anyone know if this works for the GTSt ? If not does anyone know if a GTSt sump baffle is available at all ?
Spoke to a friend who does a lot of offroad racing and he says he will help me out with this (he really is very good at he old motorsport/winning thing) but if a proven bolt/weld in product is available it has to be better.... right ? |
Gez
has no status.
Cars owned: R33 GTR
might as well crack open the crank cradle and replce the bearings with some ACL or Nismo items...worth it considering it only takes another 2 hours.
Regards Gez |
Marky_GTSt
is a Fire Engine
Gez, You are absolutely right, if your going to do it... DO IT.
![]() You could also argue that if its not broke ect, But I dont hold with that, If its not broke it probably will providing you dont upgrade while you have the chance ![]() |
Adam Kindness
has no status.
hmmm, maybe
New bearings (freshen up the bottom end) New oil pump (uprate) uprate rod bolts fit oil cooler/remote filter etc baffle the sump what do you think the labour would be on that lot? |
#14 (permalink) |
langerdan
has no status.
i fitted tomei sump baffle 2 days ago very straight forward although you may need half shaft oil seal after doing the job as you have to pull out the shaft and shaft tube in order drill bigger holes in the oil supply jets from top of sump to bottom of sump seal doesnt come out easy so you will make sXXt of it
#15 (permalink) | |
Simonh
is still rebuilding
Cars owned: R33 GTS-t
I have a spare sump for sale if you want one to play with ![]() Simon |
