There does seem to be an engineering issue with some RB30's running massive piston/bore clearance. Oil comsumption is crap and they are noisy. Mine has 0.006" some have even more. I think the guy's in Oz/Nz like this. Personally, I think it's sh1t. I'm runing 0.003" in the wisecos. The ACL's were causing the engine to use 1L of oil every 700miles.
ACL pistons or 0.006 clearance is not the reason you used 1 liter of oil every 700 miles, you obviously had other issues to cause that.
In the past we have done some RB30's with Ross or Venolia pistons with 0.006-0.007 clearance (recommended by manufacturer) and although a bit noisey when cold they have run fine, made real good power and there has been no issue with oil consumption or DET.
We now use a different piston that runs 0.0035, its quieter obviously but other than that there is very little difference.
Rob
R34 GTR: Quickest street trim skyline in NZ, 9.7 @ 137 on 1st test pass, first meeting in the UK, 10.4 @ 144.
240z, WRH8.71 / 162 @ 2 bar, stock crank, full street trim
1972 240z, RIPS RB30, quickest/fastest Jap street car in NZ 8.71/162mph 2 bar, No NOS, street tyres.
e-mail
rips@inspire.net.nz
www.ripsltd.com
