Old 27th March 2007, 03:29 PM   #1 (permalink)
Benji Linney GTC
Benji Linney GTC's Avatar
Post ATS&ACROSS CARBONETIC
Carbonetic LSD and clutches.
GTC are UK distributors for ATS&ACROSS Carbonetic range of Carbon clutches, carbon LSD's, brakes and gear sets.
Carbonetic offers a fantastic range of products including the worlds only carbon LSD – lighter, no noise, longer life, less service intervials.
The Carbonetic carbon clutches are considered the best in Japan, superior to that of Exedy and also lower priced. Some of the best race cars in Japan and Oz run ATS carbonetic including ATTKD Tsukuba R32 and ATTKD 350Z, Amuse Titan Carbon R34, GTR700 drag 8.1 and many more…
Future products being tested now include carbon pistons, carbon rotors, carbon calipers ! + more
All products are Japanese made.
The Carbonetic PRO-SPEC single plate carbon clutch is designed for standard and medium tuned vehicles up to approximately 400bhp and delivers nearly double the torque of a convensional clutch, with maximum clamping force of up to 1600kg. This clutch combines high performance with effortless operation making it perfect for fast road and street applications where traditional heavy duty steel clutches make driving in traffic and hill starting difficult. The Carbon Clutch composite also provides dramatic weight reduction and improved syncronisation during shifting
The Carbonetic TWIN plate carbon clutch is designed for High performance street and racing vehicles up to approximately 900bhp and delivers powerful transmission performance, with maximum clamping force of up to 1350kg and massive frictional capabilities. This clutch combines unbelieveable performance with effortless operation making it perfect for racing applications as well as fast road and street use where traditional heavy duty steel clutches make driving in traffic and hill starting difficult. The Carbon Clutch composite also provides dramatic weight reduction and improved syncronisation during shifting
The TWIN plate clutch kit includes: Pressure Plate, 2 Friction Plates, release bearing AND LIGHTENED FLYWHEEL!!
Available in SOFT (non drag use), STANDARD (street and track), TYPE R (drag)
The Carbonetic TRIPLE plate carbon clutch is designed for extreme power as high as 1500bhp for street, racing and drag vehicles. The Carbonetic TRIPLE clutch is astonishingly strong and is built for repeated abuse and continuous "side stepping" or "dropping" the clutch peddle and delivers powerful transmission performance surpassing that of the single and twin clutch, This clutch combines unbelieveable performance with effortless operation due to the high frictional capabilities of carbon making it perfect for RACING and DRAG applications as well as fast road and street use where traditional heavy duty steel clutches make driving in traffic and hill starting difficult. The Carbon Clutch composite also provides dramatic weight reduction and improved syncronisation during shifting
The TRIPLE plate clutch kit includes: Pressure Plate, 3 Friction Plates, release bearing AND LIGHTENED FLYWHEEL!!
Some FAQ:
1) It is possible to buy replacement disks and overhaul kits.
2) Carbon clutch kit includes push to pull conversion. Clutch kit includes: Pressure Plate, Friction Plate, release bearing AND LIGHTENED FLYWHEEL!!
3) Single carbon clutch with 1600kg cover clamp force can hold around
350ps. Twin with 1350kg can hold around 600ps or more. Triple with 1350kg can hold 1000ps or more
Further info can be found on ATS&ACROSS CARBONETIC
GTC
JAPANESE PERFORMANCE TUNING PARTS
Tel: +44 1438 833367 Mob: +44 7970646620
SUPPLIERS OF THE BEST JAPAN HAS TO OFFER
GTR 23
New Nissan R35 GT-R SUPER STORE - ENDORSED & PARTNERED WITH THE BEST TUNING HOUSES IN JAPAN & USA
PERFORMANCE EXHAUST UPGRADES * ECU REMAPS * DIAGNOSTICS * BRAKE TECHNOLOGY * SUSPENSION TECHNOLOGY * OEM GEAR BOX / ECU SOFTWARE UPDATES * AERO DYNAMIC PARTS * JDM ALLOY WHEELS & TIRES * IMPORT & TECHNICAL ADVISE + MORE…..
MY UK NISSAN GT-R APRIL 2009
Benji Linney GTC is offline   Reply With Quote
