Are you saying the CAS was never an issue or it was and now its fixed? Explain a bit about the ignition and what you learned. All the talk and theories about cam/crank timing belt variance/timing belt tensioners ect,ect....wasn't the problem? There had to something to all of that since so many people knew about it and had possible explanations. I still don't know if I understand all of that but I am happy your car is running again and even happier that it is running WELL!!! After all you have gone through, you deserve some good fortune!!!
