Aitch,
Are you saying that I may have grounds for a refund from Bridgestone?
To be honest I was using Toyos and could not find a set when needed.
I then decided to buy the S03 on same size as the Toyo's.
Bridgestone Engineer came out and discovered my tyre pressures were on the low side.
They recommended 32 psi each tyre - Rising Sun did the tyre pressures (when cold) drove home and nearly crashed! The car was just tramlining all the way bk.
The engineer told me that the tyre was stretched and gave me details regarding this.
He told me that it was possible that the Toyos were slightly wider and even 1mm would make it sit properly on the rim..
I did a search and I found out that TVR was experiencing tramlining at low speed.
If you have any addational details I would be very grateful as I just brought the tyres and just want my money back so i can buy the Toyos.
Richard
