ADMINISTRATOR
H.I.D Fitting guide - R33 GTR
HID FITTING GUIDE
Ok, this is really simple, but to aid you, I’ve thrown together a fitting guide. This is for the H1 headlights on an R33 GTR. This guide is based on the kit supplied by Car Accessory UK - Thule, Momo & more Contact the user S2GTR for price and availability. Ok, first up, the contents of the kit 2 x Ballast, 2 x Lamps, 2 x Power looms (attached to lamps in this pic) OK Stage 1 Find your headlights. They are the big glass things on the front of the car. Now, pop the bonnet and look at the back of them. In this guide I will explain how I converted the dipped beam on the passenger side. Obviously repeat for the driver’s side accordingly. The green and black wires in the pic above enter the lamp housing via a plastic cap. Turn this 90 degrees anti clockwise to reveal the lamp and its connections. Remove the spade connector from the back of the bulb, and use a flat headed screwdriver to prise the brass tag off the lamp housing. Then, unhook the small spring holding the lamp in place, and remove the lamp from the housing. You need to pull these two connectors through the hole in the plastic cap, so, ease out the grommet. Now, using bull nose pliers, crush the back of the plastic cap, where it surrounds the wires. Do this enough to break the plastic, making the hole big enough to pass the wire through. ![]() Ok, now you will need a 21mm drill bit or wood bit and a drill. I used a wood bit stolen from my father in laws shed, so I don’t mind if I ruined it Ok, now drill out the back of the plastic cover Don’t worry if the edges are rough, the kit comes with a grommet to cover them. You now need to take the lamp, its 2 black wires, with the grommet and red and black wires with spade connection, and gently pull the spaded red and black wires through the grommet So you end up with this section left over, NO I wasn’t pissed when I took this shot Right, take the lamp, and being careful not to touch it with your hands, with the grommet attached, feed it through the plastic cap. Push the grommet into the hole you’ve cut and make sure its seated correctly. Assuming you’ve done it right, you’ll now only have 2 black wires passing through the grommet, with the whole item looking like this… Ok, now the fiddly bit , you need to insert this new lamp into the headlight. This lamp is longer then the original and can be a bit fiddly to manoeuvre into place. Be sure not to force it, take your time, making note of the flattened section on the lamp, and the corresponding indented position on the lamp housing. Once you have the lamp correctly seated, pull the spring clip back into position, and refit the plastic cover. You should now have the original spade connectors loose in the engine bay, and the new lamp connectors. In this picture below you can also the see the spade connectors on the loom section in the second picture up (the pissed one, remember) Ok, nearly there. For the minute, lay the ballast in the engine bay, and connect the new spade plugs to the factory connectors. I plugged RED into GREEN and black to black Then, connect the remaining plugs and sockets together. They only go one way round, so you can’t get it wrong Scary huh. That’s it. Done! For the minute keep the exposed spade connectors clear of bodywork and each other, and get ready to finish up. Firstly, test that it works. The ballast will make a sort of whining noise when you turn the lights on, and you’ll get a green flash, followed by an increasingly bright light. If this does not happen, check your connections. Here’s what you should see, obviously daylight doesn’t help, but you can see the left light is brighter than the right. All working? ok, now finish up. First thing, cover the spade connections with masking tape, to make them insulated. And finally, find a suitable location for the ballast. As I run aftermarket air filters, I had a few places I could use, but the best choice used a hole in the wing, which I used the supplied nut and bolt to secure the ballast beneath the filters Tidy up your wires accordingly and you are half way there Driver’s side is EXACTLY the same, only refitting the lamp is bastard fiddly, so please take your time. Finding a home for the ballast is tricky, and I finally, after much head scratching settled on this position. To do this I had to bend the fixing bracket, and use the washer bottle fixing screws, but it’s secure and tidy. The ballast is mounted upside down, but this is fine. Now, clean your headlights, wash the blood off your hands and wait for nightfall. I used the 5000k kit, and have had no problems with oncoming drivers flashing or anything, so they can’t be too glary, but if you do have problems, try adjusting your beam. Right, that’s it, hope that helps some of you, and thanks again to Dave at Car Accessory UK - Thule, Momo & more for supplying the kit. Mookistar p.s. yes, I know it’s not grammatically correct, but I don’t care.
WANTED - TEIN FLEX for R33 GTR FOR ALL GTR FORUM RELATED ISSUES CONTACT THE ADMIN TEAM 'MOOKISTAR' OR 'MOLEMAN' SKYLINE FAQ'S! |
GTROC Member & Trader
Superb write up Mook
Want a job Dave.
Check out http://www.fasteronline.co.uk for great deals with free UK mainland delivery. Contact: dave@a1motabitz.co.uk Buy EBC Brakes online:http://www.a1motabitz.co.uk/search.php?nameSearch=gtr Buy Piaa wiper blades online:http://www.gtr.co.uk/forum/upload/80...er-blades.html All major credit cards taken via phone or, Paypal to tony@fasteronline.co.uk Telephone 01202 896114 or 01202 894171
GTROC Member 018
I was alright until I got to the Blood bit
. . . . . . . . . . Looks good Mook
----------------------------------------------------------- R33 GTR Standard Clutch Plate For Sale/Offers My bike,s got more BHP than most!!!! Don't make me get the bike out YOU WILL LOSE!!! SKYLINE FAQs Visit Alan,s GT-R Home Page |
#4 (permalink) | |
ADMINISTRATOR
lol mook
guys, that looks really good, but what about converting the main beam to HID as my dip beam is already HID? same principle? and what kit to go for? been looking for a while but never really came to a conclusion!
ADMINISTRATOR
do you know what type of bulb your main beam is?
biggest problem i can forsee is HID takes a few seconds to warm up. so, when you flick on full beam, it'll be dark/dim for a few seconds. and again when you flick back. on the halogen type you cannot have dipped and main on at the same time, even if you pulll back on the flasher, so its best to keep the full beam as halogen IMHO. maybe whack some monster bright lamps in there, as you'll use it infrequently mook
ADMINISTRATOR
a lot of them use motorised lamp holders which move in the reflectors AFAIK
mook
#11 (permalink) | |
GTROC Member 018
Best regards Alan
#12 (permalink) |
Thanks for the tips, I just got a set of PIAA 6200k. Will try to fit them over
the weekend. Would it have made any difference/easier if you took off the bumper and the head lights? I am sure it would take even longer just to remove the bumper. |
#13 (permalink) |
GTROC Member 018
Mine have got lost at heathrow
Sorry NICKED AT HEATHROW ![]()
#14 (permalink) | |
ADMINISTRATOR
mook
#15 (permalink) |
i did the pass. side, pretty easy. I just had to change the spade connector
to a different type. Looks nice, will take a few comparisson pics tonight. I just had a bit of a time trying to mount the ballast and hide all exposed wires. I am very particular to details That is why I wondered if it would be easier or better that I do it like so. Just found out, I have to drive my car tonight......doh. I usually drive the wife's car on school nights. Gonna look odd with one HID and one non HID light. I should have done both today. |
