Old 22nd March 2007, 09:32 AM   #1 (permalink)
hyrev's Avatar
R34 MFD not working
Searched around and could not find an answer. My friend has a R34 and the MFD screen is all black, nothing displays. Took it to Nissan ad they said the screen was bad. Is there something else than can be fixed or trouble shoot? I know at dealerships they would rather replace an item like that than fix it. They put a flash light to it and could see the display very faintly. Has anyone ever encountered this before or have any suggestions what can be done before putting up the cash for a new one? Thanks in advance.
hyrev is offline   Reply With Quote
Old 22nd March 2007, 09:45 AM   #2 (permalink)
GTR abuser
EvolutionVI's Avatar
I would say,if all connectors are fine,it is a faulty screen,like they say
March.06 --->R34GTR V-spec,my first GTR arrived
March.07 --->R34GTR V-specII,a dream came true
March.08 --->R35GTR,the order is placed
March.09 --->R35GTR should arrive
Old 22nd March 2007, 10:45 AM   #3 (permalink)
baboo's Avatar
I had my MFD malfunctioned before, black screen, nothing displayed.
I took it apart and inspected the IC board and found out it was a blown fuse.
replaced the fuse and the screen is good as new again.
baboo is offline   Reply With Quote
Old 22nd March 2007, 01:05 PM   #4 (permalink)
Luckham's Avatar
Sounds like the backlight on the LCD has blown, could be a fuse I guess..
Luckham is offline   Reply With Quote
Old 23rd March 2007, 08:49 AM   #5 (permalink)
Cardiff R33's Avatar
take it out and give to a car audio electrician and they can check the screen, connections, fuses etc
Cardiff R33 is offline   Reply With Quote
Old 23rd March 2007, 08:51 AM   #6 (permalink)
DCD
DCD's Avatar
Send a message via MSN to DCD
Nissan does a replacement backlight for the MFD. No idea on pricing though
Old 3rd May 2007, 03:09 PM   #7 (permalink)
mine just died as well, took it out and fuse was blow. replaced fuse. it lit up with gtr logo briefly and went all black again. this time fuse hadnt blow
dcd any idea on where to ask ref replacement lcd part of the mfd? thought i would ask you as i believe you are actually in japan.
sean_goodman is offline   Reply With Quote
Old 9th September 2008, 11:59 PM   #8 (permalink)
hyrev's Avatar
Well, mine is dead now, happened yesterday as I was parking - WTF!
Pulled it out just now and going to check the fuse. Keep you all informed.
Old 10th September 2008, 12:18 AM   #9 (permalink)
hyrev's Avatar
Ok, fuse appears to be blown but the problem is that it is soldered in place.
Is there a way around this or does this have to go to an electrician that knows
how to solder, I cannot do that to save my life.
Old 10th September 2008, 12:29 AM   #10 (permalink)
akasakaR33's Avatar
Why is the fuse soldered in place?
I have a portable soldering iron I can bring tonight, not sure if it has any butane in it, but if it does, we can try to fix it. Bring a good fuse to replace the bad one.
akasakaR33 is offline   Reply With Quote
Old 10th September 2008, 12:51 AM   #11 (permalink)
hyrev's Avatar
I have no idea Aki, it just is. Here is a pic of it and the backside, you still up for the challenge?
Old 10th September 2008, 03:58 AM   #12 (permalink)
akasakaR33's Avatar
Hmm. Looks like it's been modified once already. I wonder why?
Old 10th September 2008, 06:03 AM   #13 (permalink)
hyrev's Avatar
Update:
Under the advice from a friend, I went to KSP, a tuner nearby, and had them look at it.
And they said they could not fix it and to try Nissan or perhaps the maker of this screen,
which is Sharp. So, off to Nissan I went. After showing them what I needed, I got the
big X with the hands - NO!
They said they would not touch it with a 3.048 meter ( 10 foot ) pole. So, perhaps I
need to take it so some sort of electrician to have sorted out. Any other bright ideas
out there?
Old 10th September 2008, 07:24 AM   #14 (permalink)
Stachi's Avatar
I have no MFD nor R34, but I'd replace the fuse with a socket for normal automotive fuses. For someone familiar with a soldering iron this should be a 2 minute job I'd do it for you, but distance slightly forbids this
Marc
Old 10th September 2008, 08:48 AM   #15 (permalink)
akasakaR33's Avatar
I think that means a trip to SuperAutobacs, Paul.
Another thought would be to take a piece of wire and bridge the gap across the fuse, but if the underlying problem is severe, this could lead to overheating and further damage, so...I don't recommend it.
Then why mention it? Would save someone the trouble of soldering out and soldering in a new fuse.
If someone has a voltmeter, this would be useful me thinks.
