Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > Skyline Town > TRADERS INDEX > GTC RACING TECHNOLOGY
Closed Thread
Old 27th March 2007, 03:49 PM   #1 (permalink)
Benji Linney GTC's Avatar
GTC INTERCOOLER
GTC FRONT MOUNT INTERCOOLER KIT
The GTC universal bar and plate intercooler is constructed entirely of high quality 6061 aluminum and the core is 100% vacuum brazed. The polished aluminum end tanks are hand TIG welded for a perfect fit. The ambient fin pitch has been adjusted to provide an optimal fin density of 15 fins/inch. This gives the intercooler excellent flow properties as well as a large cooling surface area, and the efficient Bar & Plate core takes advantage of these properties.
The four threaded mounting points along the top and bottom of the intercooler make installation simple. Typical installations require little to no modifications to the vehicle.
Features & Specs
All TIG Welded 6061 Aluminum, polished end tanks
100% Vacuum Brazed Core
High Efficiency Bar & Plate Construction
3 popular Sizes available; Custom made size welcomed
Inlet/Outlet: 3inch
Max Recommended PSI: 40psi
Low pressure drop w/ only 0.2psi at 15psi of boost
Tested CFM: 1020 CFM
Fin Pitch: 15 Fins/Inch
GTC intercooler has 3" inlet and outlet and will flow enough air for approx 700hp, with a minimal pressure drop.
What is included in GTC complete intercooler kit?
- 1 x GT size Intercooler 600 * 300 * 76 mm ( Core Size ) / GTR size 610X300x100
- 1 x Complete chrome polish aluminium piping kit
- 1 x silicone hose connection kit
- 1 x stainless steel bolt clamp kit and mounting kit
- 1 x packing box
100% Aluminium construction
Fully polished side tanks
Tabs on bottom and top for easy installation
Improved 15 big bar design with offset fins to increase efficiency
GT Core size 600mmx300mmx77mm ( 23.7 inch x 11.77 inch x 3.1 inch)
GTR core size 610mmx300mmx100mm
End to end 780mm
Inlet 75mm (3 inch) O/D
Outlet 75mm (3 inch) O/D
GTR spec £450
GTC
JAPANESE PERFORMANCE TUNING PARTS
Tel: +44 1438 833367 Mob: +44 7970646620
SUPPLIERS OF THE BEST JAPAN HAS TO OFFER
GTR 23
New Nissan R35 GT-R SUPER STORE - ENDORSED & PARTNERED WITH THE BEST TUNING HOUSES IN JAPAN & USA
PERFORMANCE EXHAUST UPGRADES * ECU REMAPS * DIAGNOSTICS * BRAKE TECHNOLOGY * SUSPENSION TECHNOLOGY * OEM GEAR BOX / ECU SOFTWARE UPDATES * AERO DYNAMIC PARTS * JDM ALLOY WHEELS & TIRES * IMPORT & TECHNICAL ADVISE + MORE…..
MY UK NISSAN GT-R APRIL 2009
Benji Linney GTC is offline
Closed Thread
