Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > Skyline Town > TRADERS INDEX > GTC RACING TECHNOLOGY
Closed Thread
Old 27th March 2007, 10:44 PM   #1 (permalink)
Benji Linney GTC's Avatar
ENDLESS BRAKES
GTC are official dealers of Endless brakes in UK
Endless develops high performance brake solutions for the most demanding competition usage and also for advanced street applications. The main products are brake pads and brake fluid for competition/street applications, but also other brake system components like calipers, brake discs and steel braided brake lines (mainly designed for street and/or semi / professional usage) are available. All with Japanese quality and excellent attention to detail.
Kits
Complete brake kits that have been tested and developed by Endless in the Japanese GT championship to come up with a system where all components are perfectly tuned to each other and is capable of supplying maximum brake force in all situations.
Available in two different designs, 4- or 6-piston calipers, with the following features:
Calipers cast from aluminum alloy and heat treated to P6 standard. Reduces unsprung weight and promotes rigidity resulting in a greater feel and control.
Increased capacity of the brake system gives bigger margins for endurance and brake life.
Specially heat-treated brake discs with 6 slots that accelerates the oxidation which gives the pads their correct behavior.
The pads are tuned for the rest of the brake system.
Also available in "Inch Up" version that includes bigger diameter brake discs for higher control of bigger, heavier cars.
Weight/Size: 2226 grams/ 255x140x55mm (4-piston),
3221 grams/ 282x157x82mm (6-piston)
4-PISTON CALIPER KIT DESCRIPTION
4-piston / 6-piston brake kit
2 x caliper, 2 x bracket, 2 x brake line,set brake pads.
4-piston / 6-piston system kit
2 x caliper, 2 x bracket, 2 x brake line,set brake pads, 2 x sloted brake discs.
4-piston / 6-piston "Inch Up" system kit
Full price range is available from us upon application and on the GTC web site
Kits in stock now
Applications also available for other models HCR32 (type M), ECR33, ER34, Z33, PS13, S14, S15.
GTC
JAPANESE PERFORMANCE TUNING PARTS
Tel: +44 1438 833367 Mob: +44 7970646620
SUPPLIERS OF THE BEST JAPAN HAS TO OFFER
GTR 23
New Nissan R35 GT-R SUPER STORE - ENDORSED & PARTNERED WITH THE BEST TUNING HOUSES IN JAPAN & USA
PERFORMANCE EXHAUST UPGRADES * ECU REMAPS * DIAGNOSTICS * BRAKE TECHNOLOGY * SUSPENSION TECHNOLOGY * OEM GEAR BOX / ECU SOFTWARE UPDATES * AERO DYNAMIC PARTS * JDM ALLOY WHEELS & TIRES * IMPORT & TECHNICAL ADVISE + MORE…..
MY UK NISSAN GT-R APRIL 2009
Benji Linney GTC is offline
Closed Thread
