Yes, the Needle will pass 180km/h.
That is why you have to use the separate Tach Output on some Cars. The Skyline has a separate Output for speed, so you will have a correct Signal above 180, no matther if you use the stock 180 Tach or a 320km/h NISMO Unit.
