I think that i will buy an Tomei oilpump, seems after much reading here and on the Australian forums that the high flow of Jun is not that good. The Tomei is at least adjustable, so running it at the lowest "flow" should be good.
As i read from the Australians, the rear oil restrictor should be blocket, and then have a 1.2mm in the front then add a external "return" for the oil, from the head to the block.
