No I mean T04Z it was worked out on the fuel cycle.
I will get an acurate bhp figure when it's dyno'd
As for the the chassis, it's not tube'd. thats just a roll cage really Mick.
The rules state...
Vehicles must retain the original chassis/body and if the chassis/body is to be altered in any way the alterations must be submitted for pre-approval to the Time Attack technical.
Has been and it's ok
No tube frame vehicles or tube frame chassis extensions are permissible unless part of the OEM structure as defined in points.
It's not a chassis tube frame, all OEM structure points standard
Space frame chassis of any description are not permitted, additional triangulation and bracing of suspension turret/mounting points is allowed.
It's not a space frame but it has got traingulations & bracing to mounting points.
I'd show a better photo of the interior so you can understand but I don't want to give too much away
