just dyno mine this morning, stsndard car with miss fire , made 256 at the hubs, but that is using the higher boost or about 0.9 or restrictor removed. The new turbos you have extend that as the amount of air going in is more as the AR in greater, you will just max out the injectors lower in the rev range.
