Mods are as follows :
Engine and Gearbox:
2x HKS GT2510 Turbos
TRUST suction piping KIT
HKS outlet piping
HKS inter cooler piping
NISMO 3 layer inter cooler
HKS front pipe
FUJITSUBO Full Titanium Exhaust System
R's 16 oil cooler
AIR INX air cleaner
ARC Cooling titanium panel
ARC oil catch tank
NISMO up rate fuel pump
SARD 700cc injector x6
NISMO fuel regulator
DI firing system
NISMO Radiator Cap
TOMEI metal gasket
TOMEI IN/EX 270°HI-CAM shaft
Cylinder modified
NISMO G-MAX twin plate clutch
CS quick shift kit
Exterior:
NISMO full body kit
NISMO front & side clear lens
NISMO Carbon Side Trims
TEIN R34 GTR bonnet dampers
Carbon Fibre FMIC Duct
Custom one-of E Marked/Approved R34 Headlights (these are set for RHD, but can be adjusted to LHD)
Clear RB26 Cams cover
Interior:
HKS EVC*·boost controller
HKS turbo timer
APEXI Power FC ECU (Mapped by Tweenierob)
USB FC-Datalogit allowing you connect to the apexi ecu via your laptop for diag/updating map etc.
Skylab Controller
BEE-R Rev Limitor
NISMO air flow meters (AFMs)
MFD2 (Onboard computer) Upgraded to NISMO
NISMO White Clocks / Custom modified to add on MPH
HKS Water Gauge
HKS EGT Gauge
HKS 2.5 Bar Boost Gauge
SABELT seat belts
Custom Carbon Fibre Mounting/Dash around centre console
VSpec2 Pedals
Alloys/Tyres/Suspension:
NISMO GT-LM4 18 inch AW (White) with Dunlop SP9000 265 35 R18 Tyres
GReddy Type S Suspension
DBA 5000 Front Discs
DBA Rear Discs
Ferrado DS2500 Pads for Front and Rear
NISMO Braided Brake Hoses
Audio/Video:
Boss DVD/TV/MP3 Head Unit
Clarion MFD Video Cable (allows above headunit to output dvds to the MFD).
Cat 1 alarm with blackjack etc.
Car has two boost settings, high and low, low is set to 1bar, and high to 1.5bar. This gives just over 600bhp with SUL.
