Old 8th May 2008, 09:35 PM   #8 (permalink)
GavGTR
GavGTR's Avatar
Send a message via MSN to GavGTR
Originally Posted by Scott View Post
I believe the old gar required you run the system up every month to lube the seals, if no thtey can go.
So if your seals have gone, you could have all of your brand new gas pi55 out into the atmos.
So its more than likely the seals may have gone. Need to check that has happened in anycase. This is why maybe full service on the AC would be in order. Most guys can detect leaks and replace seal(s) I believe.
But finding someone who can do it and also have the adapter for the R12 to R134a is the important part I would say.
Kiwi in Surrey + GTROCer
"Own a GTR - RESISTENCE IS FUTILE!"
GavGTR is offline   Reply With Quote
