Thread: Timing a Cam in
Old 13th May 2008, 03:03 AM   #11 (permalink)
frostmotorsport
frostmotorsport's Avatar
no it's not - but then I think the factory setting for a clutch pressure plate for Evo 1-3 is something silly like 25ft-lb!! which is not much past finger tight tbh!! but that's what the book says!
my OS clutch plate is done up to 40ft-lb or something a bit more sensible.....
I would say with cam bearings (any bearing in fact) - STICK to factory settings otherwise you could cause bigger (more expensive) issues!!
