Old 16th May 2008, 09:37 PM   #9 (permalink)
matt j
GTROC 011
matt j's Avatar
Send a message via AIM to matt j Send a message via MSN to matt j
Originally Posted by jza80 View Post
The only way to do it would be to reverse the cutoff plate inside the projector assy. It is possible, I guess but would likely be very difficult. In your case, it may be easier to procure similar-sized projector units from some other brand - that is already LHS. Maybe Audi? Then swap them in place of the GTR units.
The cutoff shield is quite a substancial block in the Xenons, it is possible to reverse the unit but it wouldn't work as it'd be in the wrong place - you'd have to either file a new profile and then adjust the aim or manufacture new cutoffs.
As for replacing the whole projector unit, this is something I'm currently doing and upgrading to BMW Bi-Xenons with LHD/RHD capability inbuilt.
It's quite a big job but the results should be worth it.
Apparently Japanese Performance Magazine voted my car the second best Nissan of 2008 - Not bad for a car that hasn't had an engine and gearbox in it since September 2007!
