99% of the people on the Innovate forum that have issues like you simply do not have their gauge setup correcty. Attach a laptop computer, open logworks, and look at your AFR. If it matches what your gauge says than, that is your AFR. If it doesn't then you need to configure your outputs to match what your gauge is expecting. The 0-5v curve is easy, easy, easy to set up.
