nope, same Tomei Poncam 260/260 9.15mm lift. I'm mulling over getting adjustable pulleys so that the cams can be degreed in, but I'm suspicious of adjustable cam pulleys - I keep imagining them working loose and then the cams causing the valves to smash into the pistons...
by proper run in, are you talking the "gradual" method versus the "hard" method? I'm planning to do this one gradually, run mineral oil for at least 1000 miles, as the HKS Titan piston rings are new and harder than OEM rings.
