Originally Posted by First
So basically you can just get the accessport and connect it on the car and reset the code?
I dont undertsand what you meant by without installing? As in you dont have to pair the accessport unit with the car first? You could just plug it in and reset code and plug it out?
What I mean by "without installing" is exactly what you described above. If you have a friend with a GT-R AccessPORT and your GT-R has the bonnet light on you can use his AccessPORT to clear the codes on your car. It is as easy as plugging it in and going to a menu item and selecting "Reset ECU"
Joe
