Old 21st June 2008, 05:59 AM   #32 (permalink)
1990BNR32
the dummy head i used for my overbore to 87mm was shipped out to me from XS engineering. it is about 2" thick and it is *HEAVY* so I'm pretty sure it's not aluminum.
the explanation i was giving is that you just need something on top of the block and torqued down to the same spec you torque the head to at each head bolt/stud hole because the bores will distort with/without something bolted on.
kismet, a question for you... i was under the impression that the Cosworth bearings only come in two sizes, standard and race. from your original post it seems like you were able to get 2 different sizes of main bearings from Eric at XS. did you get 3 standard and 3 race bearings or did you actually get them to send you over or under sized bearings?
1990 Grey R32 GT-R - Sold!
1997 White R33 GT-R Vspec - Sold!
2000 Black R34 GT-R Vspec
1990BNR32 is offline   Reply With Quote
