#16 (permalink) |
Yes but since the Turbos act off of exhaust gases and pressure from the Motor anyhting that significantly affects the engine power will directly affect the turbos, though not as much as NA. Car and plane Turbines dont work the same from what I know as auto turbines are completely driven by exhaust gases from a motor and plane turbines have motor that spin them and they work of air speed though them.
Partially educated guess FTW. |
#17 (permalink) | |
Thicker air will bring more power...fact of life, cant fight physics! |
#19 (permalink) |
Administrator
That's how I understand it. Dense is good.
#20 (permalink) |
Engines use air in 'weight'. Eg 14.7 kgs air to 1 kg fuel.
So if the air is 'thinner', a little more boost will force in the extra 'weight' to compensate. This is my point, the stock ECU can compensate for altitude to a certain pressure, and I wasn't sure if 4000ft would show much on a dyno. |
#23 (permalink) |
Oh no, here is yet another "dyno thread" that will elicit all kinds of "I spotted Big Foot" stories and claims that the dyno operator or equipment was faulty, lying, substandard, otherwise doctored.
Talk of millibars and barometric pressures, intake, exhaust, timing, altitude sickness, base camp, sea level, below sea level, vacuum of space, low Earth orbit, distance of Moon from the Earth, tidal locking, sulfuric emissions... all will be thrown around and never agreed upon as being credible or plausible factors affecting horsepower and torque curves. Yet some will insist they saw Big Foot anyway and carry this out to several pages. |
#24 (permalink) |
Aircraft fly high because the stiction over the wing is less therfore the engines run more "cannot spell" economical i have served in the RN now for 12 yrs worked on sea harrier and merlin mk1 so as stated the higher the car the less air yes but the car wont know the turbos spool the same speed and engine wont run as good
#25 (permalink) | |
At higher altitude, the temperature decreases. The colder the air temperature, the better it is for the jet engine as it convert fuel more efficiently at low outside air temperatures. Basically, the efficiency is directly proportional to the temperature differential. The greater that temperature differential is, the more efficient the engine. Colder air is also good for jet engine operation. Colder mass means more air. Remember the principle of a gas turbine engine - it requires air to be sucked at the front, compressed, combusted then expanded and blasted out through the jet nozzle (a more simplistic explanation - suck, squeeze, blow and go!) Further, when a plane climb higher, the air outside gets thinner and less dense. This has the effect of reducing the forward resistance. So we are both right, but I dont agree with the last bit about the turbo, see my first post |
#26 (permalink) |
The R35 GT-R has supposedly good compensation for altitude.
Everything I have heard about it, is that it works well ,unlike 99.9 percent of the other cars on the road. This is my actual real life experience with turbocharged cars. Not a theory in a book, or what happens in an airplane. You can go on and on about theories, and I will tell you realities. I looked up the highest point in the UK, its 2000 feet. You guys don't have to deal with it. If you want to try it out Paul , come over to LA. We will run a car at Pomona which is 1200 feet. We will then take the same car, the same tune and go up to Bandimere which is 5000 feet. The car will lose about a second in the quarter mile. If Palmdale was still open, I would show you any car, even a turbo one will lose about 0.4 - 0.6 second , same day, same temp, same fuel, same engine management. Get the same car, on a cold dense day in Baltimore, on a good track, and it will be quicker still. I'll pay for the trip if you prove me wrong in reality rather than theory. |
#27 (permalink) |
Guys the fact is that cars just run slower up high. I have a 2002 WRX with a STi turbo and supporting mods and only can put down 250whp and about 265tq at 5800 feet in Boulder, Colorado. Back at home in NY though, with the same tune, it puts down 272whp and 283wtq. The spool time and just general responsiveness of the car is night and day going between altitudes...and its sucks
#28 (permalink) | |
Comustion Engine - combustion at constant volume. Gas Turbine - combustion at constant pressure, therefore trying to squeeze more oxygen into a fixed volume is not an issue. However, after a point, generating lift becomes difficult due to low air density. You either have to have a high-lift wing design (longer wings), be lighter, or fly faster. Last edited by R33_GTS-t; 29th February 2008 at 09:26 PM. |
#29 (permalink) | |
But a turbo and jet engine are very similar in operation Last edited by paul cawson; 29th February 2008 at 09:44 PM. |
#30 (permalink) |
Overall efficiency = {[(Mass flow*Ambient Speed)*(Jet Speed - Ambient Speed)]/mass flow fuel} * (1/Net calorific value of fuel at constant pressure)
Mass flow is down but ambient speed is up (less drag) and SFC is also down. It's about efficiency rather than power. From the above equation: [Mass flow*(Jet Speed - Ambient Speed)] = Thrust for simple jet Another way of looking at it is to say that the specific thrust increases with altitude, i.e. the thrust per mass unit of air. Last edited by R33_GTS-t; 29th February 2008 at 10:02 PM. |
