i most say ive was checking out pumps and ive sort of done my own research ive bought a tomei oil pump in the end with trust baffle kit and sump extension from what i have found tomei oil pumps they give you 3 discs which u can adjust the oil presure with and because of a completly different design of pump you can put these discs in with out taking the sump off not like the others if u have the money the quality of this pump is remarkable ive found out that jun oil pumps crack easy not sure if cause is the crank balance or damper pulley or the high revving but they still work but leak oil and plus them being a high flow oil pump i would recommend sump extension if i had a second option on pumps it would have been the trust oil pump as i have never heard anything bad about it but nothing really any good about it ever
n1 oil pumps are exactly the same as oem pumps with just a uprated spring in it all in all if u going to be doing low revving not exceeding 6000 then the n1 or oem pumps will be fine if u going to hit 7000 or 7500 ill would get a trust pump if u want to hit 10000 there is 1 pump that can trully proberly handle it for the money and that is tomei pump
