Old 24th June 2008, 10:49 AM   #3 (permalink)
Light-R
Light-R's Avatar
Send a message via MSN to Light-R
it might be mate.
i have bled the brake system yesterday and spilled a little bit. the distance between the brake oil reservoir and the pressure sender is around 20cms, but after the little spillage i washed it with alcohol and it might have gone a bit to the wire terminals. i will try to check it today.
my doubt regarding possible pump failure, its because when you shut down the ignition, the stock oil pressure takes around 5 seconds to drop. but its well true that the hks oil pressure was showing 0 for more than 5 seconds.
lets just hope my pump is ok.
if anyone can shed a bit more of light i will check it this afternoon.
thanks again mifn
Light-R is offline   Reply With Quote
