cooling system
i have just changed out the inlet gaskets on my R33 GTR it seems now i have a air lock in the cooling system i am getting hot air via the cars heating but have no pressure on the rad hoses my question is when you undo the bleed bolt at the side of the fuel rail should it just be a dibble coming out or should it be a jet also is it so inportant to do this when the engine is cold by the time i got the hole unblocked the engne was hot and yh coolant just dribbling out
ps i have done a search but not muc mentioned
