Old 25th June 2008, 02:48 PM   #41 (permalink)
SamuraiSam
SamuraiSam's Avatar
Originally Posted by SkylineUSA View Post
If the guy all ready has them, then he is good to go. That was my point. I never said they were better
Understood, agreed
Originally Posted by meorhalil View Post
I am putting in a GTSS in my car and would like to know if a single tomei fuel pump rated at 276 l/hr sufficient? It is rated 590PS at the tomei site. I am using a 660 cc/min injector. What should be the ideal fuel pressure setting? Would 3 bar above manifold pressure be enough for the injector in term of delta pressure for good control and flowing capacity whilst not stressing the fuel pump?
-A single Tomei 276lph will be wonderful for your setup.
-The ideal fuel pressure setting is stock, with a stock fuel pressure regulator and a stock fuel line. This setup will cause no issues with 'stressing' the pump.
