Originally Posted by SamuraiSam
99% of the people on the Innovate forum that have issues like you simply do not have their gauge setup correcty. Attach a laptop computer, open logworks, and look at your AFR. If it matches what your gauge says than, that is your AFR. If it doesn't then you need to configure your outputs to match what your gauge is expecting. The 0-5v curve is easy, easy, easy to set up.
Tried what you said and connected the lc-1 to my laptop and logworks matched the data from the gauge
I still dont believe what logworks and the gauge is telling me 11.5 on tickover and drops into the low 9 range on boost , it should be fouling the plugs and covering the road with black smoke at that ratio but it isnt , the car is running really well but is certainly a little rich
