Old 30th June 2008, 05:54 PM   #6 (permalink)
rayman
rayman's Avatar
Send a message via MSN to rayman
Some info from the optima website
The OPTIMA YellowTop
Demand more from your vehicle? Then get more from your battery. OPTIMA YellowTop batteries are made for the extremes. Whether your vehicle is designed to take the abuse of off-road driving or even cranking out decibels, you need increased performance and reliability from your battery. OPTIMA batteries combine patented SPIRALCELL® Technology to deliver that performance. The deep cycle characteristics of this technology coupled with its extreme resistance to vibration provides performance vehicles with the repetitive power they need, packaged in a spill-proof compact design.
If your vehicle is fitted with high drain accessories such as additional lighting, tracking devices, ICE systems, winches, hydraulics etc, then this ultimately demands more from your battery. OPTIMA YellowTOP batteries provide the extra performance and deep cycling capability that your vehicle demands.
The OPTIMA RedTop
The looks alone generate plenty of interest. But it's the patented SPIRALCELL® Technology in OPTIMA RedTop batteries that's truly worthy of praise. OPTIMA RedTop batteries are built to withstand the abuse Trucks, Racers and 4x4's experience on and off-road. SPIRALCELL Technology immobilises the internal components of the battery, enabling OPTIMA batteries to withstand incredible amounts of vibration.
Vehicles modified for improved engine performance demand more from a battery. OPTIMA batteries withstand the high engine bay temperatures associated with these Performance vehicles. The sealed construction makes the battery spill-proof, even if you install it on its side! This prevents external gassing and leaking which can damage engine components and reduce battery performance.
If your battery is used in applications that demand extra reliability endurance and performance, or if you just take pride in getting the best performance out of your vehicle, OPTIMA RedTop batteries deliver the performance you demand.
Yellow top is best suited, especially if have a tracker, power hungry alarm etc..The YellowTop can endure many charge / discharge cycles without losing significant capacity. OPTIMA batteries are also ideal for seasonal use because of its very low rate of self-discharge.
Thus allowing you to store your seasonal vehicles (classic car / boat) throughout the winter, without the need for regular charging and still spring out of the starting block when winter is over.
Hope this helps
rayman is offline   Reply With Quote
