Originally Posted by UKPAISLEY
Interesting, ! Prob not a coil , reason is the coil is effected in two ways, first it reacts to high temp and then performs badly, you dont describe this, as you have a problem from the start, and again the coils show spark problems under load or hard boost. I would go for the plugs, and go for NGK , you would also need to look at the temp range of the plugs as the higher ones have a littlle problem not running at high boost so are a bit lazy until the revs get up.
thanks for your imput what range of plugs would you suggest
