Old 19th July 2008, 12:09 AM   #4 (permalink)
seve7
Originally Posted by mambastu View Post
Do you have a support bracket between the downpipe/front pipe and gearbox and do you have a flexible joint in the front pipe ?
x2 its good to have a flex joint somewhere near the downpipe. alot of the heavier turbos i would use bend some aluminum and bolt it to the compressor housing or i would drill one of the bolts and tie it with safety wire to head similar to the way brake rotor hats use safety wire.
seve7 is offline   Reply With Quote
