Old 19th July 2008, 11:19 AM   #2 (permalink)
Zoltarc
According to ROM EDITOR the R32 GTR ECU has a fuel map up to 8000 RPM. I suspect the ECU will use just use the last cell in the map for revs above 8000 RPM but can not test.
For load I do not know what "value" (and I use the term loosely) the ECU uses so I can not convert the hex value into a sensible measurement for you.
Zoltarc is offline   Reply With Quote
