Old 19th July 2008, 07:13 PM   #1 (permalink)
tuRBy
tuRBy's Avatar
More cam lift? to help spool, large turbo
If i change my cams lift from 9.1mm to 10 or 11mm will this make a large turbo spool faster, or earlier? if so by how much ? a hundred rpm, a few hundred?
is there a negative effect/s to having 10 or 11mm cams?
what duration cams will I need to hold a power curve that increases up to 9200rpm ? 280/272 or 290/280?
tuRBy is offline   Reply With Quote
