Thread: Engine swap?
Old 20th July 2008, 09:19 AM   #2 (permalink)
Ian C
Ian C's Avatar
Originally Posted by KOOLER View Post
1) What the correct name of the box with nuts and bolts mounted on the left side of the engine. Is it called "front differential" or "distribution box"?
2) Guys who had sold me the whole motor told me I should use this original "front box" (no chance, my one was running w/o oil by previous owner so close to does not exist) I have and not the one they have sold me with the motor as their one has different "trasnferring numbers" so I'll ruin my both front and rear diffs with it. How can it be?
1) I assume you mean this 'box'
if so, yes it is the front differential, which is mounted in the sump casting.
2) what was running w/o oil, the engine or the front differential? (they have separate oil systems)
If you mean the differential, count the teeth on the two differentials and compare them. R32 & R33 are the same, R34 was different.
Ian
+10 extra bhp for £55....
Get your baffled TWIN TURBO pipe now from GTR.co.uk Shop
Ian C is offline   Reply With Quote
