Old 20th July 2008, 05:12 PM   #6 (permalink)
paul cawson
paul cawson's Avatar
Originally Posted by tuRBy View Post
is there a negative effect/s to having 10 or 11mm cams?
what duration cams will I need to hold a power curve that increases up to 9200rpm ? 280/272 or 290/280?
High lift cams give more torque without any effect to the power band so they are worth having.
As Steve has said long duration camshafts push the power band up the RPM range a must for big BHP but no good for low rpm response.
If you are pushing enough air through the head the long duration cams will help lag, but will make it worse on lower BHP engines
