I would consider the Hondata system a chipped ECU since originally you had to run a ROMulator and burn an eePROM. Hondata just developed their technology to the extent that they have a daughterboard situated inside the ECU which stores data and programming. I consider it a standalone since it is fully programmable unit that has raw input and raw output, not a pass-through fooler unit.
