Thread: Engine swap?
Old 21st July 2008, 03:52 PM   #7 (permalink)
KOOLER
KOOLER's Avatar
Send a message via ICQ to KOOLER
I understand this. I'd like to know how can I be 100% sure in any of this cases (working or NOT working) w/o calculating the teeth on the gears.
I was told recently the gauge is a calculated value not actual measured.
If the people who sold you the box said it has a different gear ratio, and you put it in your car, you have killed your transfer case. If it actually has the same gear ratios, then you are fine.
KOOLER is offline   Reply With Quote
