Old 21st July 2008, 05:26 PM   #12 (permalink)
tuRBy
tuRBy's Avatar
Originally Posted by paul cawson View Post
11mm camshafts require a lot of work, new valve springs, retainers, pockets in the pistons, stronger cambelt, head work for cam clearance.
You will also need a bigger duration to ramp up the lift, or have more valve train wear
thanks, do you know whats the max lift you can run safely without pocketed pistons?
and whats the minimum duration i need with 11's?
tuRBy is offline   Reply With Quote
