Originally Posted by seve7
haha useless engine? its still the most powerful racing engine on the planet. the aftermarket iron blocks are considerably more durable, and make more power than aluminum blocks of the exact same spec because they stay more true under high power and loads. no other engine is nearly as robust for making extreme power for long periods of time. if you might have worked on one of these engines you'll understand. in street trim i've seen these engines make upwards of 1000hp natrually aspirated to the wheels through an automatic on 94 octane pump gas. on 116 octane fuel with turbos, over 2000hp has been done. almost all the fastest landspeed cars with pistons use hemis. all the top fuel drag cars use hemis. what else would i want to use?
What you say is true and I'm sure they are a cool engine but imagine what could be done with jap technology in a big cube engine.
Your big street/strip hemi's don't make alot of hp per cubic inch, even your 2000hp 550ci motor is only 3.6hp per ci, our usual fully streetable RB30's run between 5 and 6 and some more street/drag orientated run 7hp+ per ci.
Even if you went with a bullet proof, pump gas, street tune with a jap tech 550ci that could give 2750-3000hp (5hp/ci) with ease, in fact, wastn't there a blown 4 liter toyota V8 powered kit car that was street legal in the US with around 3000hp a few years back, sure I saw it in some magazine, looked sort of like a big version of an ultima too.
Your car sounds great, and hats off to you, lets see some pix and video, but beware if the japs ever put their minds to building some big cube engines!!!
Rob
R34 GTR: Quickest street trim skyline in NZ, 9.7 @ 137 on 1st test pass, first meeting in the UK, 10.4 @ 144.
240z, WRH8.71 / 162 @ 2 bar, stock crank, full street trim
1972 240z, RIPS RB30, quickest/fastest Jap street car in NZ 8.71/162mph 2 bar, No NOS, street tyres.
e-mail
rips@inspire.net.nz
www.ripsltd.com
