You are saying I am wrong when, after I have provided a lot of good, factual information, you say things such as: "I good piggyback installed/ tuned correctly will do for me"
I write correct information. I have shared my experiance. I have tuned cars with SAFCs and seen cars with eManages and other so called good piggybacks blow up because they are garbage.
the stock ECU is mapped as high as the stock AFM sensor range, which is about what the stock turbos are good to before they break. Zoltarc already posted this and he is correct to the extent of my knowledge. Around 400whp worth of air.
